HELP with Sketchup 2024 not fully loading my project!
I need help with my sketchup! For some reason, when I open my skp file it load but everything is shown blank, even if I download anything from 3D Warehouse. I can still click on my scenes tabs, tags, and even if I click in the blank area, the entity info shows me what I’ve selected. Any way this can be solved? I also tried downloading SKP 25 and it works there, I just rather work on the 2024 version :frowning:
Share the file so we can see what you’ve got. Otherwise we can’t help you.
Why do you prefer to work in SketchUp 2024? Since you have a current subscription you can use SketchUp 2025 or even 2026 and if the file work in 2025, why not just use it?
Roof.skp (724.2 KB)
My file was working perfectly fine last night. My Windows got updated, does that have anything to do with this issue?
Perhaps. Might be a bad graphics driver update. That happens with Windows updates sometimes.
It opened in SU26 just fine, too. I fixed incorrect tag usage and purged the file. Maybe this will work?
Roof tag fix.skp (700.2 KB)
Thanks! All my files work perfectly fine in Sketchup 2025, so I guess I’ll be using that one from now on!
