Help with creating street light lantern bowl
I should be grateful for some advice and guidance on creating the attached. I’ve gone as far as I can using Curviloft; but the result is unsatisfactory (see model on the right of the basic mesh. The angles of the bowl are different for the front and side elevations.
Any help would be much appreciated.
Regards.
Andrew
GEC 9481 Curviloft 3.skp (5.1 MB)
Using Bevel* and Fredo JPP extensions.
Instead of Bevel you can use FredoCorner.
Many thanks for this suggestion. I shall certainly try it out.
Regards.
Andrew
