You all were super helpful w/this lamp earlier, and now I have another conundrum. I am trying to recess the red glass of this shade up into the wood part of the shade. The glass is 1/8" thick so the recess should also be 1/8" thick. I tried to merge them and pull[mushroom desk it up 1/8" but that didn’t work. thanks
lamp29.skp|attachment](upload://76Bc5St65bmZ6dMWry2eahNgOXF.skp) (5.3 MB)
Dan
BoolTools2 requires that the components are solids. The shade isn’t solid. You could use the same method for cutting the shade that was used on the base.
I redrew that shade from scratch in SU, I don’t understand why it is saying it’s not a solid. It took me forever and I don’t want to go through all that again if it will just say the same thing. Attached is the latest version. Any thoughts? thanks
Sorry to keep pestering you w/this model. I have spent hours trying to plug that darn hole that you and the inspector showed me and I can’t do it. I have tried using the pencil and tried copying and pasting other parts etc. I feel like there must be a way w/o redoing the entire shade.
"The dome at the top has no surface on the underside " - I don’t have to worry about that because that is glass. I just need the wood parts to be perfect for the CNC router software.
I don’t know what you mean about the inside surface of the shade being reversed. It looks normal to me.
thanks
Dan
