Help out modeling this
How to model this ? It will curved edges like this . Initially i thought create a shape with two parallel lines and curves on both edges kind of like thin flat shaoe snd create path and follow me but what about the curves at the end?
Whats do you mean by model if metres are mm?
Side view and push pull? Is it possible with push pull, my idea was to draw the profile and then create a flat type shape with curved edges snd then follow me?
Radial bend, part of Fredoscale.
GIF 25-11-2025 12-25-36 PM
You have first created the object with follow me right? Can you elaborate it? Fredo scale is free plugin?
It’s a path and a profile, what’s to elaborate?
No, its 15USD.
Tried to make a path like the shape of utensils then created a rectangular profile with curved edges and used follow, lots of broken geometry , missing faces?
I haven’t used follow me in the way you have used , like the profile is repeated two times and makes a thick object. The result of the product is exactly like which i want though
In SketchUp for Web with native tools
can you send the file is it possible?
not able cut thrugh the curve!
If you just show a picture, at least show the hidden geometry also.
Why do two vertices appear in those places?
For the basics of SketchUp, Campus - learn.sketchup.com
If you want to share the model, you need to download it and add it in a reply.
abc.skp (153.1 KB)
The model doesn’t look like what you showed in the picture, nor is it like I showed in the video that it can be made with native tools.
my bad here is the correct file, thats the old one. heer is the one i made following your tutorial
ABC.skp (436.8 KB)
It’s still not what you showed in the picture, but you can cut what’s needed.
it is that and you can see I am trying to cut the sides as curves and its not happening, curve is drawn at one side too you can see. i have nor pulled high like you just because i need a thinner version. you pulled almost 16 to 17 com wheras i am keeing it to 2 cm. now i need to curve the edges of hook which is not being done, i tried with a higher pull too but it diidnt wrk . can you try and cut pull push to a curved edge like you did to the ends in video?
How complex / detailed do you need this to be? Here is a simple quick all native tools version.
10
You could add the rounded edges after using a small arc and follow me with the path of one side and then mirror that side. This might require some small stitching at the join of the two arcs but is achievable.
11
