Help, How to Divide divide surface of a cylinder
i need to divide the surface of this cylinder per feet, so that i may put different colors on each feet. please help. :slight_smile:
i already solved it, just view the hidden geometry along the surface of the cylinder, then connect the dotted lines until you form a circle along the surface of it.
Probably once you’ve posted a question, you should wait and see what information comes back rather than cut it off. I suspect that the method below would cost less effort than the method you discovered.
-Gully
