Hi,
RShape.skp (149.6 KB) eally need help closing this shape, how do I do it? need to know shape volume for ordering purposes.
Hi,
Are these corner positions correct? The presence of a tilde before some of the dimensions indicate they are approximated and not exact. I noticed you have Enable Length Snapping turned on under model info >units which can lead to these small errors.
Anyway assuming you want these measurements here is how to close the shape. I reversed your faces because they were backside out (white is the front side). Open the group for editing and then draw one line corner to corner across the bottom.
It’s worth noting that you will get a different volume depending on how you close the shape.
