the default for Screen Capture [⌘⇧4] on a mac is png, it saves to the Desktop…
Applications/Utilities/Grab.app saves to tiff but opens in Preview where you can name and save in any format…
both are ‘native’ on all mac’s…
john
john
These are listed under System Prefrences->Keyboard. Then keep Preview.app open, Cmd-N to paste into new window.
With the Windows Snipping tool, I can paste the grabbed image directly into a forum post with no need to save it as a file first. Can’t Mac users do that? I last used a Mac with OS 9 so I have lost touch.
Thanx @john_drivenupthewall John! I will try this next time I need to upload something. I was turned onto exporting as a 2D graphic in the SKUP File menu. It works just like screen capture it seems.
@Barry, I’m not sure what you are saying. I went to Preferences>Keyboard and, yes, everything looks the same (all same are checked), so are you saying I need to use the up-arrow/cmd/3 to copy the screen, then open (what) new window and paste? Sorry, I’m a bit confused on your post. R~
Yes. I’m used to using Command-Shift-4 followed either by drawing a rectangle with the cursor to capture a portion of the screen, or spacebar and click on a window to capture one particular window. That process saves a .png file to the desktop. If you use Command-Control-Shift-4, it goes to the clipboard instead. To hit all those keys, I seem to need to make a “horsey” with my left hand, where the middle finger is the horse’s head and all the other fingers are the legs on the keys.
^ means control key
means Shift key
means the Command key
Command-Shift-4 will copy and put on your pasteboard. So try that, then hit command-v in a reply forum post to insert it.
You said Newbie, so it’s all good…
If you want to show your project for discussion in the Gallery section, the File-> Export ->2D Graphic method is the best choice because it just shows the project.
If you want to discuss using SketchUp in the forums, the screen capture method is better because it shows the SketchUp user interface environment like tool bars and palettes, dialog boxes, etc.
