well when i get it ready and stuff i keep getting
overlaps - please consider reducing your offseet
but its not extending outside the thing
no matter what i do it just doesn’t seem to change th result
so i ran it and i got this horrific result
how do i fix or how do i get it to coroperat
fred06 it was working for me before but this has ben happening to me
As DaveR asks, if your cube is ‘too small’ SketchUp can’t create small edges, and Round Corner will fail.
Make your cube a component, scale up a copy of the component 100x or 1000x, and try again on the large copy.
Changes there will be scaled back down to the original - SU can’t create small edges, but can preserve them if scaled down from a larger version.
Search this forum for a more detailed explanation of ‘the Dave Method’.
Actually I just realize my accident
The offset was big I accidentally forgot the numbers got to be smaller
The cube is 20.24mm x 20.24mm by 20.24mm
I made the offset 19mm way past the halfway mark
So I set the offset to 1mm then it was fine
The offset was too big.
system
closed
#5
