Cómo crear distintos grosor de líneas en planos arquitectónicas
SketchUp has only one line thickness. You’ll need to do various line types in LayOut. So you’ll need to have SketchUp Pro + LayOut
Not quite. SketchUp has three types of “lines”: Edges that separate two visible faces, Profiles that are edges with no attached faces or only one attached face visible and Section cut edges. Edges always appear thin but the width of Profiles and Section cut edges are determined by your style settings. This can also be exploited in “2D drawings” but you get good results with a minimum of hassle if you create your plans as actual horizontal section cuts of a full 3D model.
