Getting Solid Tools to work on complex shape
Hi All I have a model downloaded from Sketchup Warehouse and am trying to trim it. It’s a complex shape and using Solid Tools, I get the same problem as other community members have noted - Skp says that the shapes are either not a solid or are locked. Neither object is locked. I tried exploding them, no help. I read DaveR’s comment but have not been able to find Solid Inspector 2 in the extension warehouse. I am running Skp Pro 2024 on a mac M2 chip. I am attaching the file- trying to subtract the white cube from the bus, so I am left with the front of the bus only. Ideally, I’d like a smooth flat plane on the cut edge of the bus. I am attaching the model to save questions.
VW Bus Slice.skp (2.8 MB)
hello, for solid inspector² : SketchUp Extension Warehouse
you really want to trim this bus with solid tools ? It’s a component made of several components it can be very long making each of them solid groups and substract one by one
it’ll be faster exploding the bus geometry and intersecting with a face !
Just search for Solid Inspector.
Might as well get both of them while you’re at it. The old Solid Inspector sometimes catches things Solid Inspector2 doesn’t.
You’ll have a lot of work to do to be able to use Solid Tools on that bus.
Might be easier to cut it with Zooro2 from Sketchucation.
With Zorro2.
slice
