I’m new here on this forum and I’m having a problem with the GeoLocation tool.
1st. Grab tool doesn’t work properly. When I pick up the blue dots they displace and I can not use them.
2nd After I’m pressing Grab the image says couldn’t load image and in the terrain mode appears the rectang that I choosed and no image with “Sorry couldnt load image”
3rd. Maybe it is a problem from my browser ? I’m using GoogleChrome.
Either oblique views from Google Earth or orthogonal views from Google Maps are available by toggling the View button in the Add Location window.
One can also rotate oblique views 90° with each click of the Rotate View button.
@mafteicatalin
In your screenshot the Add Location window appears to be set in oblique view.
Try using the Add Location feature in orthogonal view.
In the oblique view it is working. Now its saying I m not connected to the internet :)). SU has big problems because I intend to buy it ? Maybe its doing this because it is a trial version. Altough I’m still studying and I saw that after the 30 day of trial it is going to be free. SU MakeUp
By they way it’s saying “You are using a browser that is not supported by the Google Maps JavaScript API. Consider changing your browser. Learn more Dismiss” Lets change the browser than
It’s not Sketchup that has the problem. As you can see in my screen shot, it works fine to import the Google Maps view. It sounds to me as if you need to update Internet Explorer and perhaps Javascript.
You need an up to date version of ‘Internet Explorer’ [v11?], and your ‘Internet Options’ should be not too onerous, and javascript etc needs to be enabled…
