I’m trying to put a 2.5 inch offset bend in a 4" inch tube. (see images) what I did in reality was to slowly heat a piece of 4" PVC until it was pliable and them gently moved it into place. The problem is that SketchUp does not have a blow torch tool. (I checked).
I have tried follow me and a few things with the move tool that did not work. I know that there are extensions that would help but they are unavailable to me. I’m sure the answer is in the Follow me tool but i cant seem to get the tube to move vertically without moving on the horizontal axis as well.
I’m not sure what problem you had with Follow Me. If you draw a path along the center line of the tube and a ring perpendicular to the path at the end, you should be able to run Follow Me with no problem.
I found the Options button that is hidden in plain sight on the Import File dialog after complaining loudly in the original SketchUp forum about DWG import not supporting metric units. I was firmly but cordially put into my place.
