Generate report... with component angle?
Hi,
Does anyone know if it is possible to generate a report including the component rotation angle?
I want to use the [Component name, X, Y, Angle] table to program a punch machine.
Thank you,
is your version 8? I am not really sure how it was back then. With 2018 you’ll have the most advanced version of generate report.
Key thing is that you add the Rotation attributes to the component in the Components Attributes dialog, then you would be able to choose them in the generate report.
Thank you. It is solved.
Version 8 Reports only work with internet disabled (otherwise tries to connect to 3d warehouse).
I will try to solve this annoyance with a plugin (ReportGenerator by TIG) might work.
If it does not, I should upgrade
Thank you again
