What exact version of SU2026 are you using?
As I remember there was a second update of SU 2026 where others reported this issue. I think it is solved in the later updates.
You might try reinstalling Sketchup ( - perhaps download fresh/latest copy -) right click on the installer fileand Run as administrator) and select Repair if it is a same version you have installed.
Hi, thank you for gaussian splatting plugin. Finally the department i work bought a sketchup subscription. I tried a gaussian splat i made using postshot. Render with sketchup ai.. I add a simple house drawing in the scene..
Could you update to the latest version, the error message should be a bit more helpful now.
If it still does not work, could you share with me the files in your %TEMP% folder files looking like this (GS_INIT_LOG.TXT, SU_SPLAT_INIT_FAILURE_*.txt (if any), GS_SHUTDOWN_LOG.TXT) and send them to me ? (%TEMP% folder is something like C:\Users\user_name\AppData\Local\Temp)
I haven’t been able to use Gaussian Splats in a while, and now I’m starting a new project and really need it—especially since Scan Essentials causes SketchUp to crash every time I try to open it.
I have an stable internet connection, its not wireles, it´s connected directly with a 10gb cable. actually the generate splats is no more on the Add new drop down menu
Hi,
You’re using an old version of Trimble Labs which is not public. Currently we have an issue with the GS generation part and we suggest you to use third party methods for GS generation (see there https://help.sketchup.com/en/generating-gaussian-splats )
Best,
YS
Sorry I asked you for the wrong file, do you have a file that looks like SU_SPLAT_LOG_ inside your temp folder ? (You need to open sketchup and try to load a sample splat first)
The files that you shared with me show no issue.
Btw, next time you can drag & drop the txt file on the forum post instead of pasting the full text inside the file.
Best,
YS
That log says you aren’t using a Gaussian splat, that you’ve loaded a point cloud.I get a message that also tells me that if I open it in supersplat or other viewers expecting GS data.
This is what somebody told you 8 days ago on the sketchucation forums also
Hi,
Good news is that the GS extension is working well for you. I could load your file inside SketchUp but using Scan Essentials because it contains a point cloud. (see screenshot)
Ply files are really tricky, they can contain meshes, point clouds, gaussian splatting and probably other kind of things as well. In the latest version, there is now a message that asks you if the document really contains a gaussian splatting.
Other test you can do when you have an issue is to use another splat viewer (e.g. SuperSplat Editor) and check if it works,
Best
YS
