No one using our @ahs.bucks.sch.uk domain can sign into SketchUp, it just cycles round to the login page over and over. I can see from some other posts that our domain needs to be added?
Thanks,
Tom
Thanks,
Tom
Hi @twilson, thanks for the post. That is entirely a possibility and I am happy to get you added to our database right now. By the time this post goes live, you will be all set to deploy the app if you have not already done so. Just make sure you deploy the app correctly as improper deployment is another common cause of the issue you are seeing.
If you are still running into the issue after this post is live and you are sure you deployed the app correctly, try clearing cached files and cookies as they can be a big cause of issues too.
If nothing listed in the post helps, let me know right away and we can start running through support steps to get you up and running ASAP.
