There is an extension called flattery that will unfold things like this, but if they are as simple as this you can just use the rotate tool to lay them out.
If it was symmetrical you could do it mathematically.
Thanks for your reply @Box. I have managed to move them into flat, but it’s too much work the way I do it. Another issue is in in process of export, the measures change slightly
