When using the freehand tool in Layout there is a white area in the arc of the line. For example if you have the the grids showing when you make a curved line with the freehand tool there is a white area around the curved line. If you intersect 2 curved lines one line will not show because of the white area. I would assume its a simple fix but cannot figure it out. Thanks
Found the Answer. Its the fill option under shape style. Click the fill button.
