I just tried to bevel the edges of an octagon and i got an error that says ‘reference to deleted Entity’.
I’ve never had any issues with octagons and FredoCorner before. here’s the .txt file it generated.
Did i do something wrong or is this a bug?
I don’t even see the hexagonal shape in your model. While I was looking at it I did a little poking. I note that the faces in your terrain are reversed. Should be white front faces up.
There are a few other reversed faces that ought to be fixed, too. I also fixed incorrect tag usage and purged unused stuff. All edges and faces should be created and remain untagged. It’s a good idea to purge unused stuff periodically to keep your model clean, too.
Wow! I didn’t know unused components took up so much space. nor that i really had any to worry about. I also know pretty much nothing about tags so if there were any they were either mistakes or things from deleted warehouse models.
hexagonal shape was off to the side of the terrain a little bit. I think i accidentally gave you the skp file before saving it. I’ll remember to save next time. the issue isn’t happening anymore so all is good.
