Fredo 6 Joint Push Pull not working
Problem:
Fredo6 Joint Push Pull is not working. The tool is there, but clicking the buttons does nothing. Hovering over the different buttons J R V, etc… highlights them but clicking has no effect.
Background:
Fredo6 joint push pull was working on my old computer. I bought a new computer a week ago and brought everything over, all my extensions, shortcuts, etc…
What I’ve tried to fix this:
Re downloaded and installed the rbz for the tool and separate one for the library a second time, also rebooted.
I thought maybe I’m past the free trial, but Sketchucation says it’s free and there is no link to pay, although it mentions a trial period.
One maybe clue, maybe nothing, for no when opening SU today, it warned that my file paths were incorrect and said to go into Window>Preferences>Files and fix all the ones that are red. This just started They were all red, so I just made a folder and set them all to it. Not sure what this does but I assume it’s for things I create, not program functionality. I had not tried Joint Push Pull after installing a week ago so not sure it this has any relevance.
Everything else is working fine. Any suggestions?
The version of Joint Push/Pull that works in SU 2021 and later is not free. It requires a purchased license. You must also have the Sketchucation tool installed. You should be using that tool to install extensions from Sketchucation.
Are you still using SketchUp 2021?
If you have license, just activate it on your new computer.
Could you also copy/paste here the content of the Ruby console when you invoke the menu Window > LibFredo6 Settings… > Fredo6 Plugins information for Sketchucation Support. This will give a precise status on which version you have and what is licensed or not.
