Frame smooth mounting end
#1
Hello I’m trying to make a tube end fitting with a smooth surface (from tube to flat)and one side (contact place) flat.
see picture.
pls. advice
Albert
stoelframe2.skp (365.3 KB)
#2
Is the tapered tab with the hole in it supposed to be part of the tube? Or is it added on to the flattened end of the tube?
#3
Dave
It’s all made from the tube.
When there is something to repair I like to use SU for a drawing.
This is a good learning process.
#4
Add. I tried to use separate parts bringing together an d than intersect to model.
#5
There are a number of threads related to drawing the transition from round to flat. You might have a search using the magnifying glass icon in the upper right part of the forum screen.
#6
for SU Make nothing useful found. any advise?
#7
Did you read this thread? I see some options for SU Make here.
#8
Abraham
Thanks for the info. I’ am going to work with those examples.
Albert
#9
