So, when doing a polygon, say hexagon, you can alternate between both ways of tracing it (inside or outside the circle)
But when you check the radius later (and maybe want to change it), it only shows you the inscribed radius, not the circumscribed, even if you drew it in circumscribed mode.
it would be a good addition to have both dimensions available in the entity info panel.
here is a 1m radius polygon. I drew it inscribed, so it gives me the radius from extremity to centre in the entity info panel.
here is a 1m radius polygon. well not exactly, since it’s a polygon circumscribed around a 1m radius circle. therefore it gives me 1,15m in the panel.
But I drew it as 1m. so if I want to change that dimension with precision, I have no other (simple) choice than re-do it.
having both dimensions available would be good.
