For sign to slice 5
the slicer 5 is unsigned …how can i sing in?
You can use unsigned plugins without any issue, only the developer of the plugin can do that, but it’s not something that affects how the plugin works.
There are many older extensions that are either not signed or their signature is outdated.
Slicer5 is one of my old unsigned extensions… its name and subfolder don’t follow the ‘signability’ rules and to redo the code to address this would be simple but the tidying up of the old folder etc would be a pain !
They can still be used if you set the Extension Manager’s Loading Policy to Unrestricted.
Restart SketchUp to see the change.
You cannot [should not] sign another persons extension…
PS: Please use Google Translate your text, because otherwise it’s all but impossible to understand.
i have a problem with exporting slicers and flat ..generate blank image on png or empty file on dxf . is this problem of 3d model or sing in. now i try a cube and the slicer is ok,
Could you use translator? Sing makes no sense in this context.
what I want to do is modify a 3D model in parametric form with slices. after clicking slicer 5 plugin the slices appear and after clicking slice export to png and dxf the folder is empty or the png images are blank. I thought the problem was the sing out extension but after I tried a simple cube model it worked. can you help me what I need to do to the 3D model so that the slices can be downloaded in dxf format
There must be a problem with the 3D model you’re working with, if you share it a member can check what’s going on with it. Signing or singing an extension has nothing to do with the problem.
This has absolutely nothing to do with the extension being unsigned!
The slicer works, you can export to dxf manually if the extension is failing to do that, just place the camera on top with parallel projection the go file/to export/2D and select DXF
