It felt like a seriously powerful feature when released, lots of fanfare, and rightly so! But then they didn’t work and seem to have fizzled out!
For me, and likely many others, this feature promised to be a game changer.
I’ve tried using snaps and found that their basic flaw is that their orientation of operation can’t be determined/ selected- Maybe there are others?
And they alter the bounding box of components… which can screw up material take offs.
I never pursued to see if they affect if a component / group can be a solid with an embedded snap.
Actually the orientation can be determined by the color of the circle surrounding the point by the color which matches the front and back face colors in the selected style.
Normal orientation matches the face orientation.
I haven’t found snaps to be useful for my work but I can see how they might be for some users.
I gave up on snaps because for what I model (mainly furniture) they require more work than plain components with appropriate glue-to and origin. It takes the same amount of work to find a target inference point and then you have the additional work to get a snap set up correctly at that location.
here I was, just trying heads-or-tails with an average 50% failure
with your white/red style it’s obvious. with a white grey or my blue / darker blue it’s not as obvious.
I think we spent too many years without snaps and thus we don’t feel the need to alter our workflow.
it’s like the lasso select, it’s great, I never think of it, I’m hardwired to select rectangles ![]()
I trained a guy who lays pipelines and gas installations. I explained the snaps, showed him how to make them, at the end of the training session he already had a dozen different machines plus several standard lengths of pipe ready for future use that would just snap in place.
@RichardJeffrey I’m not promising anything, but if you hope to see them evolve or for the dev teams to fix something you see as broken, you might need to give them more infos. they can’t fix what they don’t know is broken ![]()
Do you have a specific case in mind ?
I think it’s easy to miss with the default style back colors. My default style’s backface color is green so not as subtle as the usual blue-gray. I changed it to reddish to make it less subtle.
I think that’s a great application for snaps. In most of the models I do the majority of components get built in place. For things like cabinet hardware that gets reused I find snaps to be too much work, especially when dragging instances in from the Components panel since you have to drop and repick the component unless you have the origin coincident with a snap point.
Yes, for anything where you have standard parts that attach to each other in consistent places and orientations snaps are great. That just isn’t what I normally do.
Thanks Dave. Decided to take a look at snaps again. I wasn’t aware of the back-color thing. The functionality is better than I thought previously but needs a re-think. The ability to get an object to rotate in position and locate it easily against a surface isn’t quite there yet.
I thought I’d already covered this in a long thread, duh! Obviously not!
I have run through the isues with one of the Sketchup team members:
I did however do up a video that explains the issue of embedding snaps within non scalable sub groups of a component! Firstly they don’t show, either the pick up or their landing (excluding the tooltip), so essentially, its faster to position using regular inferences!
The other issue, if embedded within the highest level of the component, they cause the components bounding box to bounce back to the original size if the component is scaled, though the component itself is scaled, and so any accurate rescaling is lost!. I assume this is due to other sub groups being embedded within the component!
BTW, this embedding of groups in a component I’ve found, while it creates unexpected behaviours, one of these is a serious advantage: It sets as NON-SCALABLE any textures applied to the upper level component, fixed non scaling textures is something I’ve been requesting since my days on beta testing. Who’d in would come through what’s obviously an error in function!
Here are a few posts where the issues were raised:
I’ve never used snaps, I’ve been using SketchUp since 2009, for me the best snapping feature was the one released in 2020, being able to grab and snap the bounding box was a huge time saving feature. I’ve never used the snaps added in 2023, I don’t even know what they can do that the regular snapping doesn’t do.
The overall issues with SNAPS!
For those that don’t see value in snaps, that’s cool, don’t use them, but please don’t vote against updates to them. For those that haven’t used them, if you need to regularly connect components at set points, snaps (if they worked) are gold! I do think the original fanfare was warranted – albeit short-lived.
Why we need them:
We compile panel layouts for buildings; we need to connect at the bottom plate corners, and with varied-width faces that, when modelling, are whisker thin (6mm in 135mm), collecting a panel at the exact junction is near impossible. Thus, we can burn multiple hours, ensuring all is set accurately.
Snaps tested on a dumby panel component showed we could compile a panelised home in under an hour, and without any accuracy issues!
This is just double clicking the move tool to bring up the stamp tool. No chasing inferences, and absolute accuracy!
Got it, I use plugins for that.
We might be noticing different functionalities! Here’s an image from another users post that shows how powerful this tool is!
Profile builder is much more useful for my work, Profiles and assemblies help me to create accurate budgets like any other team with BIM features would do. I use it with Quantifier pro which is great for creating budgets saving me hours if not days of work.
Yeah profile builder is great for that stuff! It doesn’t work in our situation as we get like 2 panels in and then a window, 2 more then a door. It’s the locational accuracy that’s killing us!
Darn, it again didn’t make the cut! Duh!
question, how are you rotating your snaps so easily?
Josh, in the animated example I have:
1 snap to the outside centre of the black marker, orientated outward to permit inline attachment of copies, and 1 snap to each side of the black marker, orientated inward to permit cross attachment of copies!
You then don’t need to rotate the copied component, but move it above the snap, where it auto-rotates and snaps in place! In our production model, we’ll have 1 per long face, located centrally, which may not be the panel junction position, but to simply utilise this auto-rotate feature.
The first issue is we have these 3 snap points embedded in a non-scalable subgroup, so their location remains consistent; however, when embedded in a subgroup, they don’t display or are not readily selectable.
The second issue is, if they are embedded in the top level of the component, the component can’t be scaled without its bounding box only, returning to its original scale!
I’ve done up a quick diagram that I hope makes this setup clear:
