File Exception
Anybody know what this means:
FileException
Appears as though this window means I cannot save changes to the file before close out.
Any clue what’s going on?
I think I worked through the problem, but still don’t know what was going on.
Don’t save directly to Onedrive. It can cause problems when autosave kicks in and there is an issue connecting to the file, it then makes a 0.tmp file and things get screwed or you end up with a corrupted file.
Basically only work on files saved locally and manually sync to other locations.
We have had similar reports from someone saving straight to Dropbox. Do you know what steps you were doing that always showed that error? If you worked through the problem, what did you change to make it work?
