Feature request combining 2 objects
Combine.skp (317.7 KB)
Hi Guys, any body sometimes have issues with navigation, like you want to make one group to "conect with another group. It does not happen all the time but when it does, you know that feeling when the object you want to move to another but it seem to want to go everywhere except where you want it to. Just putting this forward as a feature request for consideration. What if you could join to objects together but for instance you draw a line between 2 objects then right click and then the 2 points and combine them so the 2 points at each of the line and make those points as pert the image
Usually this means the component you are moving is glued to some face.
Take a look at Snaps
Hi Anssi, No I have been using this program for a while "clue would be the first thing I checked
This is a completely unnecessary step. Moving one object to another is just as easy as drawing a line between them.
GIF 1-04-2025 11-35-40 PM
Had a bad day so can’t find the words
No(w) it’s time to look for “glue”. :wink:
