Failed to open document error with my SketchUp 2025 file - Need help restoring
Hi everyone,I am facing a serious issue with my SketchUp 2025 file. When I try to open it, I get the error message “Failed to open document”. This is a project I have been working on by myself from scratch.The file size is still large, so I believe the 3D data is still inside. I have tried renaming the file without special characters, moving it to the local Desktop, and checking the AutoSave folder, but nothing worked. The .skb backup file is also showing the same error.I have attached the corrupted .skp file below. Could any expert or admin please help me run a recovery tool on it to see if it can be fixed?Thank you very much for your support!https://drive.google.com/drive/folders/1kl3d2wAdIW4GJAwpBTlsIwQ-DFDVEPlE?usp=drive_link
Unfortunately, a big chunk of the file is filled with zeros, and I couldn’t recover anything. Do you have the SKB backup file, that would be in the same folder as the SKP?
