Failed to open document" error on SketchUp 2026 - Corrupted file from external drive
Sou um profissional de desenho técnico e tive um problema com um arquivo.
Hi everyone,
I am facing a severe issue with a corrupted project file in SketchUp 2026 on Windows. When I try to open the file, I get the “Failed to open document” error message. Renaming the backup .skb file to .skp results in the exact same error.
The file is about 185 MB and was saved on an external hard drive when the glitch happened last night. I tried importing it into a blank SketchUp model, running it through SketchUp for Web, and opening it in Blender, but the file fails to import due to central directory/checksum errors.
Could an engineer or someone from the community look into the binary structure of the file to see if any geometry or components can be recovered?
Here is the download link to the corrupted .skp file:
Thank you so much for your time and help!
Unfortunately there are a lot of corruptions in the data. Do you have an skb backup file in the same folder as the skp?
