I have a challenge for you !
I have a terrain which is a big surface made of triangles. It is not a plane since it has different altitudes, like a real map of the world. See the top part of the image.
I would like to create a “border” around it, to make it look like a small scale model out of concrete. See the bottom part of the image.
How many edges form the perimeter of the landmass? If it’s less than a few dozen, I would just manually draw vertical edges up from a ground-plane face to each perimeter vertex (using inferencing to locate the lower end of each such edge).
I think you should be able to accomplish this with Joint Push Pull (using vector or extrude?), and then slicing off bottom off with a flat plane. I don’t have time right now to do a test.
Can it be negative? After all, the earth isn’t flat, so a chunk aught to have the vertical edges converge to the center of the earth rather than flare out. Ok jusdt kidding. Oh, no! Now I may have created an irresistible challenge.
thanks again for your help !
I did use the Eneroth Terrain Volume tool, which is great and so easy to run, but ran into some issues for some part of my terrain.
Then I tried to Joint Push Pull plugin (from Fredo6, love this guy!), and managed to get what I needed. This last plugin is very fast in computing and has a lot of options, it is great !
