I have installed libfredo6 6.9, and several associated extension ie round corners. But I cannot access them
Did you install all the latest versions from SketchUcation? There were some changes in SU16 that affected Fredo6’s plugins.
Unfortunately v2016 has an unexpected glitch…
Often, after installing an extension, it is not marked as ‘activated’ - despite its file’s code saying that it should be !
If the installation was successful, then you need to use the Preferences > Extensions pane, and ‘check’ those newly added tools…
They should now be OK.
Although it should NOT apply to ‘signed’ extensions [i.e. like Fredo’s] your v2016’s Preferences > Extensions [Loading] Policy… MUST be set to ‘Unrestricted’ to avoid these kind of issues…
Thanks for the reply Pal, but have fixed the problem.
[quote=“erniehatt, post:4, topic:18307, full:true”]
[/quote] BUT since this is a community, it is customary to at least share your insights…
