COLOR MAKER 1.1.0 for SketchUp 2014 and higher (Free and Pro)
I tried the (old) extention ‘Color Maker’ in Sketchup version 25.0.660. Could download and install it, but it seems to do nothing ( and yep, read the help file pdf ). It supported older versions (16 to 19), does any one has it running (working ) on 25? Any tip would be appreciatied.
→ Emailed the builder D. Bur (2025-10-05), via extension warehouse waiting for a reply.
Internal it function, can see all the color types etc. But ‘creating a material, or ‘create all materials’ does not result in any thing. I wanted all the RAL colors, so made a map ral_colors and tried to create all materials. No result.
Mhh,… I expected it to make the material in the current showed folder, the one I just made. I did not look in the ‘In Model’ folder. I will have a look..
I went to a clean start, closed iet all, re opened Sketchup (fresh start) selected a new drawing and there it worked in ‘In Model’… @DaveR thx for the help!
I expect you did get the new materials but they were combined with the existing ones. Doing this in a new model makes sense, especially if you are going to create your own collection of materials.
As a final solution, in the clean drawing i deleted first the ‘ThomThom’ figure and removed manually all his colours one by one in ‘In Model’.
Then with the extension ‘Color Maker’ I created all the Ral colours in ‘In Model’ and saved the to a folder (yep you guessed it; RAL_color ). Now I can load that folder in any drawing I like, without overcrowding the ‘In Model’ folder.
You could delete the scale figure and then in Model Info>Statistics, click on Purge Unused. That will remove the component and all of the materials associated with it.
