Yes, it crashes even if I set only one of autocad format, dwg or dxf
It doesnât help, still crash
The loop can be deleted, the problem with export autocad format in background. Without loop you just need to loose focus faster, immediately after run the script and select the folder
I myself cannot run the code to test the crash as I do not have a Mac.
This is why I asked the questions.
I totally understand.
begin ... rescue doesnât catch the exception, SketchUp crash
Removing loop doesnât help, still crash on export to autocad when the focus is lost
The problem was in SU 2018. Now I have tested SU 2019 and it works fine!
Unfortunately my customer use 2018 version ((
