Hello -
I have a +/- 100MB file that I’m trying to export to 3D DWG. It crashes almost instantly when I try.
I have purged the model (model info / statistics / purge unused).
I also tried exploding all components and groups. Still doesn’t work.
Reading through several solutions that I found posted to the Sketchup User Forum offered no solutions.
I can export other, less complicated models with no problems. Here’s my setup:
MacBook Pro 15-inch, 2017 / macOS Sierra 10.12.6
Sketchup Pro 2018 (Version 18.0.16976)
Any thoughts?
Thanks -
Doug
what extensions do you have installed…
john
Hi, John -
Thanks for responding. I don’t know how to list all installed extensions, but I’ve attached a couple of screen captures from my Extensions Manager. I use quite a few…
Photo Textures shouldn’t be in v18, did you copy paste it into v18?
any chance the file has ‘old’ photo textures…
john
Hi, John -
I don’t think I copy / pasted it, but perhaps I did. The model was started several years ago and could have old photo textures, I suppose.
Any danger in deleting the Photo Textures extension?
…and do you think there’s a chance that the Export 3D DWG would work if I disabled all non-Sketchup extensions first?
you can re-name your ‘Plugins’ folder, restart and try…
john
John -
I tried renaming the folder (removing all non-default plugins) and it didn’t fix the problem.
Any other thoughts?
Thanks again for your help!
Doug
Could you upload the file to the 3D warehouse, or a file sharing service like Dropbox? Then someone else could see if they too have problems exporting it to DWG. Unless you can’t make it public?
system
closed
July 19, 2018, 8:49pm
#10
