I have had success in the past exporting directly from SU, which is effectively exporting geometry to Modelspace. I used to think that was all you could do. But then someone put me right and said “of course you can export from LO”. I assumed that meant that geometry would be exported to Modelspace and LO stuff would go to Paperspace with the end result looking pretty much identical on either platform. But life is never that simple is it?
Here in the UK, most of those involved in architecture/surveying/engineering still use the dreaded AutoCad and so that has become the de facto standard. So it can look a bit naff if you cannot exchange files readily between any other platform and AC. Obviously, an end user wants any conversion process to be quick and seamless and not have to dive under the bonnet each time!
If a style was used containing shading, when exported from LayOut we create an image so that they display the same in AutoCad. This will also contain the vector line work. Both the image and the line work will be placed in the modelspace with an appropriate scaled viewport. The LayOut info will be placed in the paperspace. If you do not want to send any shaded version, change your style in SketchUp to hidden line. You could also detach the images in the xref dialog in AutoCad.
The only time when exporting a SketchUp model viewport from LayOut that it does not place the info into modelspace is when the SketchUp model is in perspective. The perspective view along with the image (if applicable) are placed in the paperspace
Thanks for sending your file and I verified I could scale the text. The part that can be confusing is some of the text is placed in a block and could be edited or exploded before editing the height.
Also, we do pass a hardcoded font value that defines the style and height on multi-line text so this can be confusing as well. The hardcoded values are visible on the Properties dialog under Text ‘Contents’. It will display something like {\H25.6487x;steel cross beams…}. That H25.687 is the fixed text height being passed. To change the height you can simply change the ‘Text Height’ field of the dialog (to something like .125)
Hello! This thread has been very helpful in learning a workaround for exporting .layout files to .dwg and other relevant details.
I believe that another issue has popped up on my Mac.
I followed the instructions to click the arrow to reduce the window to just the small details needed for export, and I have had success with that in the past (literally within the past hour or two).
But now, when I reduce the window, it removes the options for export, and I am confined to pdf export. I have already tried to close the application and reopen it to see if anything needed resetting, but this didn’t help either.
@dgoforth this is a known issue with High Sierra and now Mojave. Once you experience this issue by minimizing the dialog should allow you to select other export Format types.
I am having the same issue as @dgoforth, using Mojave, and have no export options for file types. Looking for export to .dwg. Can you explain what you mean by
Sorry about the delay. With this issue when you select .dwg as an export option, with the dialog maximized the dialog can expand and prevent you from being able to select different export options. The way to prevent this is to minimize the dialog by selecting the carrot as shown…
