Hello. I am using draw helix to model a screw. The issue is when I explode the helix which is wrapped around the cylinder; the cylinder disappears. Now I am unable to scale the helix in order to form the shape of the screw. I have attached a couple of screenshots for a clearer vision. Thanks in advance for any help.
This is way too small for SketchUp to create the small faces.
Consider edges 0.1mm the minimum.
You may want to scale up your helix by 100x and only then explode it. Scale down later.
B.t.w. isn’t the helix way too detailed? The file size is going to be quite big in the end.
