[Example] Lay a set of Selected Instances In a Row Along X axis
Example_LayInARow_1.1.0.rbz (3.2 KB)
Features:
An extension installable (and controllable) by the Extension Manager.
It remembers the last used spacing allowing it to be set via an inputbox.
The changes are wrapped up in an undo operation.
The command appears on the Extensions menu and on
the right-click context menu if instances have been selected.
Known Issues
- v1.0.0 does not work with negative axis scales - fixed for v1.1.0
The instances will be lain along the X axis of the current editing context.
If the selected instances are nested then the results may be interesting.
Test Model
v2023 : LayInARow_test.skp (58.2 KB)
v2017 : LayInARow_test_2017.skp (143.6 KB)
This came about from another topic thread …
