Everything new is appearing under one tag
I’m working on a model with several tags. Something weird happened where one of my tags is now omnipresent. I can’t turn this tag off because I get the “You can not hide the current tag” warning, and everything new that I draw is automatically labeled with this tag, instead of starting out with the “Untagged” tag. Any ideas on how to fix this?
Sounds like you probably made that tag active instead of leaving Untagged as active which you should have. Move the pencil icon at the right side of the Tags list back to Untagged where it is supposed to be and then go through the groups and components in your model and make sure all edges and faces are untagged.
Screenshot - 12_15_2020 , 3_21_48 PM
Thank you! That was the problem.
