Error when using push/pull command
So if I bring in dwg files and models from the 3d warehouse I should explode them and assign them to untagged?
Not necessarily explode them but you should open the groups or components for editing and check to see that the raw geometry is shown as Untagged. Components from the 3D Warehouse do sometimes bring tags with them and the authors aren’t always very good about keeping the geometry clean. You should always import 3D Warehouse content to a separate file and check it over before adding it to your main model.
Ok thank you hopefully that will solve the issue!
Good luck. Keep an eye on things. Hopefully you won’t have more problems but report back if you do.
Another way is to delete tags you don’t want in the tags window. Just read the warning carefully if the tags you’re deleting are not empty and make sure they get moved to the untagged layer. That would leave all the components/groups as they were and put everything on untagged.
