It is possible to add a dynamic attribute “copies” to a sub-component present in a selection using this method:
mod = Sketchup.active_model
sel = mod.selection
sel.grep(Sketchup::ComponentInstance).each do |s|
s.definition.entities.grep(Sketchup::ComponentInstance).each do |e|
next unless e.definition.name =~ /sub-component-1/
e.set_attribute 'dynamic_attributes', 'copies','3'
$dc_observers.get_latest_class.redraw_with_undo(e)
end
end
If I want to cancel the copies, it makes sense to change the value of the attribute to 0.
Thank you for your intervention which put me on the right path Dan.
My mistake was to graft the entities!
Here is the solution that works:
sel = mod.selection
sel.each do |s|
s.definition.entities.each do |e|
e.set_attribute 'dynamic_attributes', 'copies','0'
end
end
Further you open your code to fail because you have no type checking (nor filtering,) or duck typing to avoid NoMethodError exceptions.
Meaning, your supposed solution is fragile.
I was hoping you’d figure it out … oh, well.
Here is the code with “duck” typing, and validity check:
sel = mod.selection
sel.each do |s|
next unless s.respond_to?(:definition)
next unless e.valid? && e.respond_to?(:definition)
e.set_attribute('dynamic_attributes', 'copies','0')
end
end
And I could go through this forum and the SketchUcation forum, and add in links to many of YOUR topic threads where you do not understand the errors you are getting when you run code, … BUT I have better things to do.
Indispensable, … yes. It is called defensive programming.
You can not be 100% sure of the kinds of objects that will be in API object collections, … now nor in the future.
So I encourage you to use “duck typing” and validity checks on collection objects, and do not just assume the objects are what you hope them to be. (New kinds of objects may appear in future releases of SketchUp, and having code that makes “type assumptions” can easily break, upsetting your customers.)
But, … in the end it is up to YOU to implement what we have tried to teach you. I consider that you have now been “schooled” in avoiding validity, no method and type errors. I will not further respond to any more of your posts that are obviously solved by doing “defensive” checks. It is time for the “little bird to fly on his own”.
All coders need to get to the place where they can use error messages to debug their own code, and figure out where the error is (file and line number,) and what is causing it. Getting good at troubleshooting code errors makes a person a better programmer. It is part of the learning process. In my opinion, when a coder relies too much upon other people to troubleshoot their code, they do not learn as much as when they themself figured it out.
