hello all,
im trying to install the VoronoiXY.rb into my sketchup pro 2016 and i have no idea of what its happening but i can’t install at all! i tried already to put inside the Tools folder and even tried the Plugin folder but none worked. What should i do?
where did you download it from, did you read all the instructions…
you should never put anything into the Tools folder and you can use the .rbz version for foolproof installations…
john
i downloaded from here… and as the file is not a .rbz file i looked up on internet and another community said i should add in the tools folder…
click on the link [in my first post] to the authors thread at SketchUcation and you can download the rbz file with the additional ruby it needs already included…
the whole folder structure has changed radically since this was first written and the old advice is no longer valid…
john
ill do it… should i uninstall and reinstall SketchUp? because know i think my folders is a mess lol
if it’s only the one it should be easy enough to remove…
but it’s your call…
john
thanks John! i tried in another Pc and worked! ill see what i did wrong! thanks a lot!
