I did an picture to cut in sheetcam, i try export to 2d, but picture are export with error, picture stay inclined, not know problem.
i enter in option, export to dx autocad 2013, but always inclined
pleasy help
pleasy help
What happens if you change the camera in SketchUp to Parallel Projection?
And is it possible you’ve moved the model axes?
Dave , you is developer of sketchup ?
if there are in error need solve it.
You can acess remote my pc to check, add my ederangelo21@hotmail in skype… you can acess by skype.
And, if we solve, we post solution here after.
In sketchup, draw very good, and export, inclined.
No. I’m not a SketchUp developer. I don’t know what makes you think I am.
You didn’t answer my questions.
upload the skp file and we can see what may be wrong…
john
How i to do parallel projection ?
_* not know, how i check it ?_**
ok… in some hours… thanks
You don’t need a SketchUp developer. You need some training in using the program.
Parallel Projection: Go to the Camera menu and select it. Then select the Top view and try the export.
Model axes: Temporarily move or hide the geometry so you have clear access to the origin. right click on it and look to see if Reset is shown in black or gray. If in gray, it’s alright. Otherwise click on it.
As I told you before. Set the camera to Parallel Projection and select the Top view. Look at the attached file. Does it work for you?
