Error- CFileException 0 error keeps on coming up when save to DropBox
Error- CFileException 0 error, when I try to save to Drop Box.
I will try to save it locally, then save it to drop box at the end of my session. Has anybody else tried this?
It’s a bad practice to save directly to the cloud or anywhere else except your local drive!
Many people have gone before you with files corrupted beyond repair. We see them here every couple of days.
Do as you said in the last part of your post. Open and save locally. Then backup or sync later.
You could also try Trimble Connect , it’s included in your subscription and safe to use.
Thank you
tweenulzeven Oh Learned One
Sounds like good advice. Will need to get into Trimble Connect as you suggested.
Found what to do in Support.
Cheers
Jeffrey Green
Interesting, I always save to my dropbox and get this error a lot iv never noticed any corruption as such and never take much notice of the error. I will defiantly take this on board and start saving locally then back up into the cloud.
CFileException 0 means essentially “No error” but it is still an indication that everything is not going as it should. The remote location is probably not responding correctly to the save, even if it has proceeded and completed. As said many times before, it is not safe to save large files directly from an application to a remote location. Most of the cases of corrupted files daily brought to this forum have arisen from doing this.
Lots of people go years without problems, but Edward A. Murphy Jr. catches them all sooner or later..
