Enviroment Fading
If I make a new file from the “Visualization” Template, All the environments are faded at the bottom.
If I make a new file from the “Default” Template, and manually select and turn on an environment, it is the full image with the non fade.
Does anyone know how to get the environment to fade from the bottom when starting with a default template. I tried every setting in the style and environment tray and I cannot find a way to make it fade. I like the look of the fade.
The fade is fog. So just turn on fog and adjust the settings
Thanks, Just figured it out as you posted.
You can also play with ground/background to fade it with the fog
