EntitiesObserver inside not detecting ComponentInstance inside Group
I’ve been using EntitiesObserver to detect if an ComponentInstance is added or removed to the entities set. But I found that EntitiesObserver cannot detect the ComponentInstance if it is added or removed inside a Group or a DynamicComponent. So I add the same EntitiesObserver to the Groups and Components. Unfortunately the onElementAdded and onElementRemoved is not called if a ComponentInstance is added or removed, although it worked for Edge and Faces.
I found a “workaround”, by adding the Group and Components EntitiesObserver first before the active_model EntitiesObserver the methods will be called properly. But I cannot do that to the new components that is added after
Use the DefinitionObserver to detect when instances are added.
A hybrid model observer example …
# encoding: UTF-8
module Author
  module SomeExtension
    extend self
    class MyHybridModelSpy < Sketchup::ModelObserver
      def initialize(model)
        watch_definitions(model)
      end
      def onComponentInstanceAdded(definition, instance)
        puts "onComponentInstanceAdded(#{definition}, #{instance})"
      end
      def onComponentAdded(definitions, definition)
        definition.add_observer(self)
      end
      def watch_definitions(model)
        model.definitions.each {|cdef| cdef.add_observer(self) }
        model.definitions.add_observer(self)
      end
    end # hybrid model observer
    # AppObserver callbacks:
    def expectsStartupModelNotifications
      return true
    end
    def onNewModel(model)
      MyHybridModelSpy.new(model)
    end
    def onOpenModel(model)
    end
    if !defined?(@observer_initialized)
      # Add this module as the application observer:
      Sketchup.add_observer(self)
      # Set the flag to true:
      @observer_initialized = true
    end
  end
end
:bulb:
