It is not ready, but the idea is to print in on a 3D printer. My question How can I remove the ousite area?
See the picture.
Many thanks in advance for your help
Otto
Intersect the two selected parts.
Delete the unwanted outside bits.
You’ll need to use the section-cut view to see inside the form so that the internal partitions and any related edges can be deleted too…
You’ll probably need to do that to the junction of the sloping plate and the perforated wall, and wherever there are ‘internal partitions’ too…
Also ensure that all outward facing surfaces are NOT blue [use context-menu to Reverse them]
Also be aware that if this part is small enough to 3D print you are likely to encounter SketchUp’s issue with short edges and small faces. Either model as if meters are mm, or use the “Dave method” (search forum) to avoid the problem.
