Edge Highlight Issue
Testing out some code to highlight edges but there is an issue highlighting an internal edge.
External view…
highlight_01
Going inside the group the internal edge in question is of course now an “external” edge so gets highlighted as expected…
highlight_02
Here’s the code…
def draw(view)
   	if @entity.is_a?(Sketchup::Edge)
		point1 = Geom::Point3d.new(@entity.start.position)
		point2 = Geom::Point3d.new(@entity.end.position)
		#points = [point1, point2]
		view.line_width = 5
		view.drawing_color = Sketchup::Color.new(40, 144, 255, 255)
		#view.draw(GL_LINES, points)
		view.draw_lines point1, point2
	end
end
You can try and see if you get the better result when using the #draw method with a parameter openglenum : GL_LINES, GL_LINE_STRIP or GL_LINE_LOOP constants, e.g.:
view.draw(GL_LINES, point1, point2)
OR.
The #draw2d method is used to draw in screen space (using 2D screen coordinates) instead of 3D space.
But then you have to “convert” the points using the #screen_coords method to retrieve the screen coordinates of the given point on the screen.
point1_2d = view.screen_coords(point1)
point2_2d = view.screen_coords(point2)
view.draw2d(GL_LINES, point1_2d , point2_2d )
BTW
The #position method is already return Point3d, so you do not need to use the Geom::Point3d.new on it. With
point1 = @entity.start.position
you will get a Point3d
:bulb: You can get the edge vertices position into array and use this argument in a draw method
points = @entity.vertices.map(&:position)
points_2d = points.map{ |p| view.screen_coords(p) }
view.draw2d(GL_LINES, points_2d)
This is good but produces some odd behaviour…
curious_01
This makes me think of some of some odd highlighting behaviour I experience with Curic’s Extend plugin - maybe they are using the #draw2d …?
It not an odd. The method is drawing onto the screen space. So it will be “above” the model 3D objects .
If you use the #line_stipple= method, and combine draw2d and draw methods then you can achieve an effect that the “hidden” part of the edge is dotted and the really visible is solid:
view.line_stipple = "."
view.line_stipple = ""
An alternative to drawing to 2D is to offset the points you draw in 3d by a little amount towards the camera.
PIXEL_OFFSET = 2
direction = view.camera.direction.reverse
offset_points = points.map { |point|
  distance = view.pixels_to_model(PIXEL_OFFSET, point)
  point.offset(direction, distance)
For large amount of points this might be too slow, but for small amount this works wonders.
Thanks Thomas, but I can’t seem to get this to work…
So in place of:
I put…?
And shouldn’t…
view.draw(GL_EDGES, points)
be…?
view.draw(GL_EDGES, offset_points)
I’m getting this error…
Error: #<ArgumentError: Cannot convert argument to Geom::Vector3d>
Got this to work…
Changed
point.offset(distance, direction)
to
and
to
view.draw_lines offset_points
Oops, got my wires cross when I wrote that snippet, I didn’t have time to test it. I’ve updated my post.
That should have been GL_LINES.
Did it look better if you did the offset toward the camera?
Yes - it’s good.
