is there anyone that has a dynamic component from a dutch window with a square section of 67x114mm including a glaspanel? I don’t know how to make it myself and don’t have time to learn it at the moment.
I tried several 3D Warehouse components, but they are bad…
If you use SU Pro, you should be able to create DCs.
Here’s (see attached) a standard window frame with pane in its simplest form.
One parent component with:
four side profiles
four corners
one pane
The location of each nested component’s origin is related (per X, Y and Z) to the parent’s origin
(unless when it is located at the parent’s border. Then there is no need to specify its location)
So are their lengths related to the parent’s height and width.
The 67mm is a fixed profile size, mentioned per nesten component
So is the 114mm. But here I took out the option to scale perpendicular to the frame. (Easier to do instead of 8 times … Y = 11.4cm)
