This started to happen a few days back, and is only for this template, which have been using for a few years.
This behavior is only for SU 2024, and only for an empty file, if I open this template in other SU versions everything is fine.
The first time I use a drawing tool, nothing is visible, but it’s easy to tell that the tool worked and created what is supposed to, but you can’t see the objects.
The second time I use one drawing tool… everything is fine (but the first draw still won’t be visible); or if I do CTRL+Z after the first time… again everything is fine.
I deactivated any extension that I might installed in these few days… and the same thing…
If instead of using a drawing tool, I first generate a shape (with Alex Schreyer extension Sahpes, for example), after that everything is fine with any drawing tool.
Strangely enough, if I open the same template in SU 2024 (that I use in SU 2022 or SU 2023), again everything is fine, but as soon as I save it again as a template in SU 2024 (or simply save it as a file)… the same behavior.
My conclusion is that is something that SU 2024 doesn’t like about this file, but I don’t know what because the template is very basic and simple, if I open my other templates that are more complex… everything is fine (maybe because they are not empty).
Of course is not a very big deal, but if it is something I do (or have done) wrong, I want to know, for the future.
Thank you.!
Woodworking_FAp_1.skp (136.1 KB)
