Hi,
I am trying to draw in a layout (n°2) on a first drawing in the layout n°1.
The drawing in the first layout is exported from another software and it is not perfect so i need to redraw it. (I will export it in a software that needs a perfect sketch)
For example: I have a cube with 32 entities, i should have 18 entities, so i want to redraw it in another layout above it.
The problem is that even if I activate the second layout and i draw on it, It will not draw it because the line is in the first layout. How it is possible to let the first layout visible and i can draw above it in the second layout?
I hope my explanation is clear, my english isn’t so good
Thank you
