Domes again
Good morning.
I should love some advice on the attached. I am trying to achieve this dome and have created the attached using Curviloft. (Follow Me created an absolute mess). As you can see, there is a dent at the rounded ends along the centre line and I simply don’t know why that should occur. I’d really appreciate some advice on how to create this as I want it to look - a smooth rounded end|? The overall dimensions are what I want - height and arc shapes on all elevations.
Many thanks in advance of your help and guidance.
Andrew
Silverblue for Forum.skp (237.9 KB)
You could create a sphere and take the necessary pieces from it and attach them to the ends of a part of a cylinder. Only native tools - Circle, Follow Me, PushPull.
Create the shape of a Tic-Tac and cut out what you need.
Thank you very much for coming back so soon.
I did try that first of all. The problem is that the arcs aren’t the same on the green/blue plane and the red/blue plane and neither is a half-circle. Perhaps I’m betraying my lack of SU skills here (apologies) but I couldn’t make it produce the shape I wanted by creating a sphere.
Kind regards.
Andrew
With Curviloft
with native tools
Thank you so very much for that innovative (to me :)) solution. I will get to work on it…
Kind regards.
Andrew
