Domed endcap for polygonal cylinder
So I have an object in my current model that’s an irregularly hexagonal cylinder - think a triangle with the three corners truncated to different lengths. I want to give it a smoothly curved dome endcap. Any suggestions on how to accomplish this?
Do you mean something like this?
That does look pretty close to what I want, yes.
I extrude the shape through a dome and intersected the two.
Hrm. When I try that it does not maintain a face on the curved portion after deleting the stuff in front of it.
Here is how I do it.
Is your model very small?
I’m building a game piece to be 3d printed, yes. On the intended scale the part in question is about 4mm across.
The first problem I found is that the plugin I was using to create the dome left it as a Group. If I explode that before intersecting it works a bit better but I still get a lot of triangulation errors along the edges, places where it just … drops pieces out of the surface. I can go in and correct it manually but it’s a bit of a pain.
What type of dome? You shouldn’t need a plugin for a “smoothly curved dome”.
Is it possible that your dome has too many polygons?
Work at a larger scale to avoid the holes.
